Z4 V10
Tout ce qui concerne les Z4 (sauf question technique)
Bman
Z4 V10
Message par Bman »
C'est en anglais.
Un préparateur a monté un V10 de M5 avec boite méca (modèle dispo aux USA) dans un Z4 de génération précédente...
Manhart Racing - BMW Z4 V10 a écrit :The M version of the BMW Z4 is famously known by nature for being anything but underpowered, since the chassis of the sports convertible already has a heck of a lot of work with the 343 HP and the forward thrust in the lower gears could last forever.
As is generally known however, the sport oriented motorist can never have enough power at his command. Sufficient cause for Günther Manhart, who by now has over 25 years experience in rebuilding BMW engines - a first for Europe - to transplant a brand new, much stronger heart into the Z4. The transplantation of the ten cylinder engine from the current M5 generation into the narrow engine bay of the roadster was anything but a walk in the park and it earned the Manhart Racing engineers quite a few grey hairs.
Nevertheless: everything fitted in the end and now the fire of a 5.0 litre V10 engine with an impressive output of 550 HP blazes above the front axle of the Z4. A catalytic converter, a modified DME electronic control unit and the removal of the factory-set V-Max restriction up to 250 km/h are part of the rebuild. Consistent to the M5 V10 engine Manhart Racing has treated the Z4 to an original M5 E60 6 gear manual transmission which includes a Fichtel & Sachs clutch and a M5 E60 differential. An AC Schnitzer stainless steel exhaust system with four muffler tips which was fitted with HJS racing catalytic converters caters for a perfect V10 sound at the rear.
The Manhart Z4 M V10 goes like hell and thanks to the perfectly tuned Bilstein B16 PSS10 coilovers, the virtually unrestrained power of 550 HP can be brought under control to the tarmac. Black BBS Challenge wheels rotate in the wheel arches of the Manhart Z4 M V10 with 8.5Jx19 ET35 235/35ZR19 front tyres and 10Jx19 ET20 285/30ZR19 back tyres.
Conclusion: 550 HP ten cylinders, an acceleration from 0 to 100 km/h in 3.9 seconds, kerb weight 1450kg, 2.6kg per HP... who could guess that these impressive figures belong to a Z4? Hardly anyone, however Manhart Racing turns dreams into reality and does this with 25 years experience.
Via : WorldCarFans.com
Jean Ragnotti
belle réalisation !
bibou
Message par bibou »
Un V10 de 5L, c'est petit :roll:
Alors qu'il aurait pu monter un V12 de 6L :P :P
Zyxman
Message par Zyxman »
Ca rend bien dans le capot :)
Ca doit etre une sacrée bête à emmener avec le V10
Zyxman, Coupe M
Toit, toit mon toit, Toit, toit mon tout mon roi...
DriverZzz
Message par DriverZzz »
Quel dommage de ne pas avoir mis ce moulin dans un coupé :(
Ca doit quand même sacrément envoyer, et tant pis si c'est lourd du train Av :roll:
Ex Z3 3.0i coupé / New 328i E36 full stock < 50 Mkm !!
Zyxman
Tout a fait d'accord! un coupé!
Zyxman, Coupe M
sur un coupé tu le mets derriere les sieges !! whaaa!! :woot:
Bman
Message par Bman »
Oui enfin, pour le coup, le coupé, c'est pas une R5. Si tu mets le moteur derrière les sièges, il faut enlever l'essieu ! :D :D
Jean Ragnotti
si on peut meme plus rever !!!... :(
Bman
Message par Bman »
Rien n'empêche de rêver, mais chez BMW on parlera plus de central avant que de central arrière (M1 mise à part...) :wink:
Jean Ragnotti
bibou
Message par bibou »
Central arrière, y a que ça de vrai :D
Vive la M1....et l'Ultima :P :P
je crois l'avoir vu par hasard... il y a quelques temps sur mobile
Yann31
Message par Yann31 »
Bman a écrit :Rien n'empêche de rêver, mais chez BMW on parlera plus de central avant que de central arrière (M1 mise à part...) :wink:
Diiiiiiing......Le petit Dabe s'est perdu et attend ses parents à la caisse centrale avant... Le Petit Dabe, merci!! :lol: :lol: :wink:
Z4 3.0si coupe stratus & M coupe S50 cosmo
Ex. Z3 3.0i coupé oxford, ex. Z3 3.0i roadster cosmo, ex. Z4 3.0si roadster nachtblau, ex. Z3 3.0i coupe cosmo, ex. M coupe S50 dakar, ex. Z3 3.0i coupe champagne.
jj-a110
Message par jj-a110 »
DriverZzz a écrit :Quel dommage de ne pas avoir mis ce moulin dans un coupé :(
il y a des Z , qui une fois leur châssis renforcé , risque fort d'être bien plus rigoureux :D
jj-a110
hartge à déjà monté un v10 de M5 dans une serie 3
Revenir à « Autour du Z4 »
